Synchro Diagram needed for Reinstall
GSXeclipsePSI
563
7
Jul 7, 2003
New Port Richey, Florida
Ok I am taking my center diff out. And the guy helping me is my dads friend who just had to jump in, started taking parts of my 5th gear synchro apart and now I don't know how it goes back together. The shift fork is still on since we are having hard time removing roll pin.
So can I get a diagram of how it all goes together, I got clip rings and keys and I have no clue the order.
Here you go.
Thanks thats what I needed. Now if I had a video that would me super.
I think I can get it. My roll pin is stuck, I read somewhere to use a hole punch, and I used one that went in and broke off. Now I read they make Roll Pin Punches that are flat with a dimple. Should I be able to get it out if I bang it from the gears outward? I banged the punch hard on both ends, should I maybe heat it up and try again from inward out, cause i tried outside in and no go.
The tranny is in car but maybe dropping the tranny mount will give me more swing room.
Also I need a diagram of the whole 5th gear with gear and needle bearings and syncro togather.
