Switch preventing me from removing dash
Araesk
188
Jul 10, 2013
Muskego, Wisconsin
Therr is a switch on the pop Out piece under the drivers side dash, on the left side of the steering wheel. I cannot get it off because of the fog lights switch, and I cannot figure out how to remove it. It's blocking 2 10mm screws I believe, any clues??
*edit1:forgot it is a 95 eclipse gst
If you are trying to remove the switch- it looks like a regular toggle switch.
There should be a nut along the base of the "pole"? ( If I can call it that) after you remove the nut you should be able to push the rest of the toggle assembly through the small trim piece or just pop the trim piece after you remove the nut.
Chances are, there is enough wire behind that trim piece though even if you don't take the nut off to pop it off.
On the front of the switch there is a lock nut. Remove that lock nut with a set of pliers or wrench and the switch will come out of the plastic trim.
