swaybar clearance
djsven
162
Jan 10, 2003
Rochester, Minnesota
Hi,
I have a 95 eclipse GSX. I am replacing the rear swaybar with a suspension technique swaybar. It should clear most of the 3" exhaust, but not mine! I have issues with the clearance between my apex'I GT catback and the swaybar.
Has anyone else run into this problem? And what did you do to fix it?
Thanks for the help!
Sincerely,
Sven
i would try the RMDSM sway bars, they will clear the 3" exhaust, they will fit Thermal R&D exhausts, and if you email them, i think you will find that it will fit your application, they also come with bushings, and a steal at about $200-300 (used - new)
Hi,
Which way does the swaybar go, over or under the catback?
It seems like the RM one goes over the exhaust, but I don't really know for the suspension technique one.
Sincerely,
Sven
