Sunroof Moonroof Powerroof
rbrtbrce17
Aug 4, 2006
po, Florida
Hi, my sunroof doesn't work on my 1996 eagle talon base model. I took the headliner down and I don't see any factory wiring for it (all I see is some rig job the previous owner tried ) I got a print out of what's supposed to be the wiring diagram but it claims power is directed through a sunroof control computer. I don't see one. It says it should be under the headliner. Can somebody please help me!
If I can't find the factory wiring please explain how to wire it up without it. Which switch positions need to be power and ground etc.
I know my sunroof motor works because I jumped it both ways on the battery.
Thanks everyone!
there really is no wiring really, just 2 harnesses.
one harness should be your power supply that goes to the motors computer and the harness that comes off that should go to the sunroof motor.
If you know it works via jumping it, then you know what wires do what.
Im sure you should be able to wire the switch up with this info.
Or do you not have a switch ?
I think the sunroof modual is prob what senses if somthing is in the sunroofs way while closing (best guess)
i do remember seeing a box when i pulled the sunroof from a parts car
    • Sdcryan1
