tturbolife1
- 144
- 1
- Apr 29, 2008
westwood,
New Jersey
interesting symptoms never had a problem like this one. its random stuttering while my foot is steady on the gas pedal for a while then try to boost the rpms slowly move up and it feels like im running on 2 cly, my aem wideband goes all the way to ---- lean. i thought it could be the wires and spark plugs and i changed them, still happends, i took this video a while ago there some things that i thought could be causes to my problemYouTube - eclipse problem#2
this is how i fix it when it starts to stutter i have to take it out of gear and wait till it idles then put it back into gear and it drives fine . also if i stay at 14-15 afr on my wideband it doesnt seem to happen until i start to push the gas pedal down. it seems like it only happends on the highway because around town im constantly stopping and starting. this happend a while back then stopped and now its starting to happen again. i dont know the reason i was thinking its the coil pack its a 6 bolt swap 21vac no leaks everything is good it was running fine bad tps? bad isc? suggestions ?
i also read a post on a bad isc and wondering if that would cause my symptoms and also my older post of my rpms dropping on a hot drive from 1500 idle to 740 rpms?
