Stock bov size?
xxraptor660xx
815
Jul 30, 2007
Fair lawn, New Jersey
I've looked and I cant find it out. What kind of bov will be a direct fit to a stock bov flange? What size is my stock bov? Help is appreciated
u can buy flanges that will bolt right on to your stock flange that will allow an aftermarket bov to fit.
Can't find any for my car. I'm trying to put a type S. If you could maybe give me a link to a bolt on flange, i'd greatly appreciate it.
Not exactly sure what you are planning there, but here is a link to RRE's website. Check it out and hopefully it helps you out.
http://www.roadraceengineering.com/flangesandgaskets.htm
EDIT: Well shit, I see you already found RRE's flanges. As for the aluminum or steel BOV flange, it depends on the material of your UICP. I wouldn't think it would be too hard to find someone to chop off that stock flange and weld on the type-S flange.
Yes, with the steel intake piping from dejon you are going to want the steel Greddy S-type flange. Now just find a welder to switch the stock flange out with the greddy flange.
I guess you could try modifying your stock flange seeing that both the S-type and 1G flange have the same hole diameter, but I would be worried about boost leaks with that setup. Your best bet would be to take your UICP to a shop and have them weld on that S-type flange.
EDIT: There you go, the stock 1G flange has been modified for the S-type bov before; Oldman took care of that - (http://www.dsmtuners.com/forums/showthread.php?t=268718)
