Sticker?
You can just peel/scrape it off. If your windows are tinted then your gonna have to leave it, unless you wanna re-tint that window. It means the stereo will not work if the stereo is removed, not the sticker... duh.
Heat it up with a heat gun or blowdryer. Slowly peel it off with a flat blade screwdriver. Any sticker residue should be removed with Goo-Gone or other mineral spirit supplement.
You guys are real friends and you know what friends say after. "Dawg I didn't know that was going to happen". Unless you are a retard I don't see why they would have a sticker that tells you that if you remove the stereo it won't workROFL.
