start-up question??
speedy_talon28
364
3
Apr 1, 2006
elkhart, Indiana
Hi, I would like to know after I bolt the rear main seal plate in place, Is there a way that I could start the car up without the transmission to see if the new seal will start leaking or not. Or is this process simplely a trial and error
As long as the flywheel is on you could start it. The trans will not make a difference. But as mentioned earlier, as long as you did the seal correctly you should be fine.
I sure hope I did because I had no pic's to go by. I made sure the seal was level before I installed it but, I may have put it in backwards
