stalling out!!!! can't figure out why
sid_fin
Jun 8, 2004
regina,
i posted this in a different forum already but there was no response so i thought that i would try this here too (http://dsmtuners.com/forums/showthread.php?t=136482.) there's the link for some background info.
so anyways here's the problem, when i put the car in gear with my foot on the clutch everything seems fine, car idles good and sounds strong. but as soon as i ease up on the clutch pedal the car stalls, this even happens when the car is in reverse and its pretty hard to stall the car in reverse. the clutch slave cylinder has a very small hole in it, do you think that this might be the problem or maybe the clutch just isn't engaging/disengaging properly causing the motor to stall. any help would be greatly appreciated, thanks.
