squeaking brakes when cruising
carl5463729
169
3
Jul 21, 2004
Lancaster, New York
First i changed my front brake pads and i found my one caliper sliding bolt snapped in the passenger side bracket. so whenever i made a left turn the passenger front brakes would squeak. After that, after i lowered my car with kyb agx's and eibach prokit, my front brakes squeak whenver i'm driving, not just on turns. My camber is off in the rear but i'm not switching it because i'm getting another car, i recently got a new caliper bracket and bolts and i replaced it with the bad ones. And my front passenger side still squeaks when i make a left turn. The brakes don't squeak when i step on them, but just when i'm drving. it's not a "totalally" squeaking. it squeak like on a certain part of the brakes. So it's like a squeak for 1 part of every wheel rotation. I hope that makes sense. I would really just like to fix the problem. Thanks
Did you have any machining done to your rotor's or get new one's? Whenever you replace pads you ALWAYS get them turned if possible or get new one's. A warped rotor will hit the pads lightly everytime it comes around and make a squeaking noise.
ok, my front ones might be warped a little, to many 90 to 0 stops. but my rear passenger side started squeaking right after i lowered my car, i never even touched the rear brakes.
