knock when cruising?
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
I have my stock boost guage set to read knock. When I'm cruising in 4th(auto) and hit some low boost (5psi) trying to speed up, I notice that its getting some knock. Any ideas?
If its only 5psi then its most likely phantom knock. You can try to put some racing gas in it and try the same thing (100+ octane) to see if it knocks again.
well the car seems to run real good. Maybe it is just phantom knock, but its still pulling my timing. I have a keydiver chip with a stock 2g timing map on it. Any way to see if its just phantom knock?
  • Wanted 6 bolt NT water pipe
    • chrisman287
