sporadic white smoke
gotgrip666
262
Mar 29, 2005
middletown, New York
every couple of days when im driving my car and i stop at a light white smoke blows out the exhaust but its not steady i was thinking maybe its running to rich but i am not sure
also the one line that runs kinda threw the oil filter has coolant in it is that normal?
One of my buddies owned a 97 TSI and he had noticed white smoke occasionally and just assumed it was running rich on a improper tune "car ran fine didn't miss" later he started losing coolant and found he had a junk head-gasket. You might run a compression check for fun?
Best of Luck!
I agree with gotgrip run a compression test, this also happened to me :beatentodeath: Do a compression test just to make sure its not your HG. If that comes out right then check all your hoses and fittings.
here's a link on how to perform a compression test
http://www.geocities.com/siliconvalley/2072/carcomp.htm
compression checked out i changed my tune a little bit it was running really ritch also tightend up some lines and hoses no smoke since
thanks for the help guys
White smoke is not a rich fuel problem but water turning into vapor or a very lean condition. Rich would be black/gray in color.
