Speaker Neons w/ 12volt Battarie line.
cjl
Feb 11, 2005
Houston, Texas
Is there any specific place in a 1994 Eclipse N/T that a battery line runs?
I have speakers that I would like to wire with the neons that are installed on them. Could I find a battarie line going to the back seat. I am very new at anything electronic so any help would be much ablidged.
Thanks ahead. :thumb:
Id just run a line from the front under the door sills, under the back seats, under the carpet, then bring it up clean to the neons.
If I had a volt tester I could tell which one under the front would be a 12volt battery line?
Also , I do understand about under the door sills and under the seats to the side panel to the neons. :thumb:
I will find a friend that has a voltometer. Test a line that comes from the battery and run a clean line.
Thanks for the information and I will most likely post images of the install :D :dsm:
:d hey LOL , I know just so curious that 2 people wrote battarie instead , it's written as pronounced , what's so complicated with that ??
cjl said:
Along w/ this question I would like to add that I have a HowTo posted on HU.com about 88-94 DSM 6x9" Rear Speakers.
http://www.houston-underground.com/forums/index.php?showtopic=1315 :thumb:
I believe you have to registar to see the forums , but it a great howto. Pictures for everything thought of , even having to modify the rear side panels. :dsm: :thumb:
I have also submited a request to put it on the site. :dsm: :thumb:
I have just finished the install of my neon switch and I used a fuse link between the battary and the switch to the lights. This way I can run the neons when my vehicle is off. :dsm: :thumb:
I am going to post a tutorial about it. Until then check out the one I have on Rear 6x9 Speakers for 88-94 Eclipse/Talon/Laser. http://dsmtuners.com/forums/showthread.php?t=168197
  • Wanted 6 bolt NT water pipe
    • chrisman287
