Speaker Adapter
xtreme98eclipse
May 20, 2005
Bremerton, Washington
I know awhile back I saw a speaker adapter for the front door speakers. Since they are sqaure stock speakers but I have round aftermarket speakers. Does anyone happen to know where I might find a set that will work. thanx
Go to autozone or a parts store and buy the connectors that fit the speakers, there called female spade connectors, there in the wire section, and they look like this http://www.oxaero.com/Jameco-Terminal-106921.jpg
Cut the connectors off the stock speakers, strip a 1/4 inch section the jacket off to expose the wire, slide the wire into the connector, crimp the connector down onto the wire, slide the connector onto the speaker terminal.
Did you just say your stock speakers are square? Wow they really gipped the N/T guys.
What you can do is go to the junkyard and see what works, they will have a lot of cars that use 6-6.5" speakers and have the baffles mounts for them. Even better if you find a 2g that has them so you know it will fit perfectly.
Above would probably be the cheapest method, also try ebay.
  • Wanted 6 bolt NT water pipe
    • chrisman287
