sparco seats question..
WhiteCharisma
273
Jul 7, 2003
Hialeah,
hey guys whats up i wanted to know what is needed to install a sparco or a bride seat in my car ....do i need a mounting braket?... ..i would want the seat to be able to slide back and forth... thanks :thumb:
:dsm: :dsm: :dsm:
a seat slider is an option it is mounted in between your seat and bracket some companies put out permanent seats that are set it and forget it. but many companies will include sliders. my last set of sparcos had a set included.
I am installing a pair of Sparco Rev's and I had to get sliders, side mount brackets and custom made bases. I think that you may be able to use the stock bases... but you may have issues with the holes not lining up. The hardware set me back a fe bucks though!!!! I am waiting on the Megan Racing Strut tower bars to be able to tie down the Sparco Harness' to the rear one until I get around to getting a weld shop to put a cross bar behind my seats.
i bought a rolling chassis with a jamex seat in it the guy that i got it from had done this its a disaster and i wouldnt put my life on them they have to be hacked up and its really thin metal. the jamex had to have the stock brackets spread apart a couple inches and the mounting holes cut off and a put back on via a hole cut elseware on the rail kind of looks like this with the slashes a little smaller and connected SCARY! im going to replace them before i get it registered
l l
i cant get this to line up right
  • Wanted 6 bolt NT water pipe
    • chrisman287
