racing seats question...
Status
Not open for further replies.
Psssshvalve
52
Oct 22, 2004
Hillside, New Jersey
whats up guys? i ddint know where this post would go so i figured over here. i want to install racing seats and i was wondering if any of u have seats because i need to know where u bolt the harnesses up on a 1g or where the best spot would be. any suggestions are appreciated..thanks
:talon: :rocks:
the best and safest place to bolt the harnesses to would be a bar right behind the seatback that is attached to a roll cage. however I'm guessing that you infact do not have a full cage. so you can: bolt it to the rearstrut bar(i think Megan racing one has holes in it) or bolt it to the factory seatbelt bolts in the back seat. i speak from experience the second method doesn't work very well and is really annoying. if you want to do it right i would suggest at least investing in a hoop and crossbar, other wise the seatbelts are not at the correct angle to function properly. hope this helps some at least
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
