Some quick questions.
eldiabloz13
612
8
Mar 2, 2005
Fairhaven, Massachusetts
Where do get that peice that connect the tranny to the engine. Its like a gasket but thicker. I can get a pic if thats what we need.
Also on all the AFPR write ups. It dosent say where you can buy the fittings and lines. I DO NOT want to buy a over-priced kit from a company. Ill even make it out of damn wood (not literally for all those stones out there) just to say its custom made by me. I like the blue and red and stainless steel fittings.
Now the stock FRP on a 1g is on the fuel rail right? If so where can i get the fitting to plug into the fuel rail also.
Im going to relocate my battery into my trunk. When doing this i will now fail emissions. Well to be plain and simple, should i re-wire my fuel pump to the stock location. Or just not re-wire it till i pass emissions so i can make the pump wire shorter. PART 2 Where is a good re-wire write up for a 1g. I dont like the vfaq ones is there any better?
When i was removing my engine i scraped the boot off the driver side axel. I used a reg clamp to put it back on for now. Should i just trust the clamp or buy a new driver side axel.
Thats all i can think of for now thanks for the help guys.
The piece from the engine to the trans..? that plate in the center???? you can get those from a dealership aand i'm sure alot of people in the for sale section have them.
An linesif thats what you are talking about for your Adjustable fuel pressure regulator, you can buy lines from most preformance shops online or one near you
The stock fuel pressure regulator is on the end of the fuel rail on the driver side (you were correct) The fitting you have to by is i think, i say this again I THINK is a 6an fittings/lines and you have to tap your fuel rail for that fitting.
For the fuel pump rewire, go to vfaq.com i know i've seen it rewire page on there
You can buy a new boot for your axle, they actaully make rebuild kits for them.
Ok thanks for the help but its not really what im looking for. I want to know the sizes and names of the fittings for the AFPR. Maybe even a website with all the listings and part numbers.
I have BEEN to vfaq and stated i dont like there write ups is there any more i can go to for refrence. Prefably on this site.
As for all the other help thanks good info. If there is anyone else who can help please do.
