tcavenger99
- 109
- 2
- May 24, 2008
mount pearl,
OK i installed a warlbro pump, 36 lb injectors .12:1 fmu , cut off end of fuel rail regulator 95 model rail, i also installed a adjustable fuel pressure regulator be for the fmu at the end of the rail, missing link. when i boost it seems like a backfire yet there is no pull from the boost ,seems like a lack of fuel. i have put a fuel pressure tester on the rail and at idle it reads 40 psi ,also put pressure to fmu and it hits 120 at 10psi . Yet when u turn the car off the pressure in the rail goes to 0 . can anyone help
. You still need a way to raise your fuel pressure for when your under boost. I would also think 25psi at idle is too low better but to low. If you had a wideband this would be 100 times easier.
