2G Soft brake line removal
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
I have the hard line off and I was able to disconnect the soft line from the caliper. I am stuck as how to get the rest of the soft line to come out. I pulled the retaining clip off and nothing is moving around. Thanks for the help
Are you talking about where the soft line goes into a fitting through a bracket which the hard line screws into and a banjo clip holds them onto the fitting? Remove banjo clip and tap fitting with hammer to wiggle it loose.
