Sneeky Pete bottle?
steve_arnocky
Sep 22, 2004
thunder bay,
hi, I know the sneeky pete nos kit won't really work on a fuel injected car, but is it possible to have a regular dry nos setup and use the bottle for the sneeky pete (or something similar - i/e 10 oz) in replacement of the regular 5 or 10lb bottle? the reason i ask is because i have no trunk or backseat room and want to use either my glovebox or center console to house the bottle.
thanks.
whats the point????????????? So you can run no2 for 1st and maybe second gear. You are furthur off running 3 more pounds of boost, if youplan on running no2 do the correct RESEARCH and do it correctly.
You can use a 20oz bottle, and it should fit in your glovebox, but you might only get 1 or 2 runs out of it.
-Brian
as said on the website , its only good for an extra .1-.2 tenths in the quarter..... BLAH
whats stopping you from buying a jet bigger than the 40 shot that comes with it. (besides the size of the bottle). nothin.
CanadianTalon said:
You'll get about 20 seconds of spraying @ 40 HP out of a sneeky pete bottle. Waste of money.
How long does YOUR car take to get down the track hopefully its less than 20 seconds :nono:
Anywayz he wasn't askin if it was worth it or not he wanted to know IF it would work. And YES it WILL work, and if he wants more runs on the track then just get more bottles they are EASY to carry around and you can set up a set of more than just one in a LOT smaller space than a regular bottle.
  • Wanted 6 bolt NT water pipe
    • chrisman287
