SMoke + PCV = Help :(
Andy5
693
Oct 29, 2003
Kenosha, Wi\Oceanside,CA, California
Well. I'm not to happy. When my car is running i get a lotta air/smoke outta the side "PCV" I think thats what it is. Some ofyou do the filter trick to stop the oil. Is this suppose to be like that? I mean theres more smoke than what i want to come out. Then when i shut the engine off open the oil filter cap smoke rises outta that its not dense but its not a lotta. and its white is this normal or am i about to do a rebuild :(
Have you done a compression check, 'cause it sounds like you could be looking at a rebuild :(. I've never had that on my car.
no no check :( the car runs smooth and pulls hard..... Dosen't smoke out the exhuast. *Sigh* This car will give me a heart attack someday
Excessive blow-by from your vavle cover would lead me to think its your rings.Trust me you don't to smoke from your exhaust at idle,start up,or when your driving normal to have a problem happening or about to happen with your pistons or rings.How much smoke are you getting?Barley noticable?Does it pour out?The only way to really tell is to get those compression #'s.Even though your car feels fast it could be letting you know that something is about to go wrong.
ya the breather ;) i'm going to do that mod but i just have to figure out were to attacth the other end of the hose to :confused:
