Small T-28
bigdogg2834
121
Sep 19, 2004
Santa Ana, California
Could someone tell me real quick what is the CFM, lb/mn Flow rate of a small T-28. And Also how much boost could I run on a stock 2G fuel system. I tried searching but all I could seem to find is numbers from the Big T28. Thanks guys.
It flows about 35 lb/min. If you have a logger just keep turning up the boost till you start seeing knock or timing being pulled. (If you don't have a logger get one). The safest thing to do is buy a $100 fuel pump and safc for 200 and tune before you upgrade a turbo. Just remember you can get the turbo with out a logger, fuel pump, safc (there are bigger better ways to tune I'm just using safc as an example) and there is a good chance it will run like crap because it's not tuned. Good luck.
When I said small T-28 I was referring to the regular one. Thanks guys. I think when you said CFM you were referring to lb/mn. But I don't think the regular one flows that much. I think thats for the Big28.
