small 16g how fast does it spool???
slow_talon
144
Jul 8, 2004
Brownsville, Texas
hey how fast does a small 16g with the stock 2g intercooler spools up or how fast does yours spool up and what mods do you have?
When I had my s16g on with stock side mount + stock exhaust. I was getting full boost in 3rd gear by like ~3800rpm. But I have a front mount and just put on my 3" turboback last weekend and I haven't really checked when I get full boost by yet. I'll let you know this weekend. I'm expecting 3400rpm or maybe a little bit less.
My small 16 is ported to hell and back. With exhaust and still on the SMIC I would hit 16 psi at 3k, now with my FMIC I hit 19 at around 3100-3200.
but at what rpms do you guys start building boost like @2400rpms or higher or maybe lower my car is an auto so i need to know how fast does the turbo spools up
I know its not a s16g, but my b16g reaches 15psi at 2800rpms. Its ported and clipped with a 34mm wastegate. I would expect a s16g to spool a little faster...
Andrew
Andrew
What are you talking about? 5th gear? Hell I can build 14lbs of boost at 2400rpm if you are. Generally, when people ask what RPM range it takes to build full boost, its on 3rd gear. And I don't think a B16g will achieve full boost by 2800 (3rd). Even the T25 has a hard time getting full boost by 2800.
when you are in first gear and pressing the gas at what rpms does the turbo starts gaining boost :talon:
The turbo starts building boost at like 2300-2400 and hits hard at a hair over 3k.
come down to md and Ill show you, and I never said 5th gear please read my post correct. In 3rd gear(I didnt specify sorry, but I didnt say 5th) I reach 15psi at around 2800. Its going so fast that by the time my eyes go from the boost gauge to the tach I probly missed a few rpms. Oh and my t25 reached, with these mods, full boost 15psi as soon as I smashed the throttle down. My b16g starts boosting when I press the gas, but is very linear, though fast. If you want proof come down here and Ill show you :thumb:
Andrew
I've rode with DSMeclipse4g63 and it does spool very quick. He's got everything ported which problaby helps a bit.
:confused: my t-25 builds 16psi at like 2,300 no prolem in third. :confused:
