slow rev and no power when in gear
jdarnold1990
Feb 7, 2013
Sullivan, Missouri
Okay first and foremost my car is really slow to rev and when you put it in car and let off the clutch you could have it floored and it will sit at 500 rpms and shake real bad and stall out in neutral however it will rev up fine. already did a boost leak test, replaced the ecu with a eprom ecu double and triple checked the timing checked the cat and almost everything else. its a 1990 gs-turbo has small 16g 500cc and 2g maf and 2g manifold. im about to run this car to the scrap yard LOL also i think its just a shitty gauge but it sits at ~10 vacuum :banghead:
i've checked timing and done a boost leak test and both are good how can i check for a vacuum leak?
anyone else got some ideas that i can go over?
could it possibly be the power transistor
