Simple Questions about Basic Meth Set-up
joyfil2001
838
Dec 17, 2007
Toms River, New Jersey
So I have been toying with the idea of getting a basic meth set-up from Devils Own. I am currently running 22psi on 650cc injectors. My question is can I simply just turn up the boost a little to like 25-27psi with 50/50 mix without actually tuning my timing and AFR? Is this possible? Or do you absolutely have to get a tune to run meth?
There is always a benefit in running methanol, even if you keep the boost level the same. However, adding meth to your fuel injection alters the AFR and you will need to retune it to make meth a power gain, than a problem.
That's what I am trying to have explained to me. In the future I will have the meth tuned to be a huge power added. But for now can I run it as more of a safety precaution without having to tune anything?
It will make you run richer than the car does currently if you don't tune it. It can make it too rich so that your car won't even run right when the meth is on. In which case it would be better to have it turned off. Hence why I said, "You will have to get a tune in order for it to run correctly."
Do you guys know of a thread that tells/explains it all about meth, how to tune with it in dsmlink, and what to get, where to put the nozzle. All the kinda stuff?
James :laser::talon:
You're all over the place today :p Of course we have threads, it's called the SEARCH button.:) Sorry I had to, but seriously, I did ALL of my research prior to buying the snow kit right here on the boards (and on link). I didn't have to ask one single question after a couple hours of reading.
http://www.dsmtuners.com/forums/articles-engine-fuel/296230-installing-snow-2d-meth-kit.html
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
