Signs of a bad ECU ??????
pinknuggit
530
Oct 15, 2003
joplin, Missouri
OK.
i got my car and it was not running when i got it.
I have no spark or fuel.
I changed out my fuel pump to a walbro 255, and i still get no fuel.
Whenever i put 12V to the fuel pump test connector on the firewall, the fuel pump Still does not come on. My MPI fuse on the battery terminal is ok, and i recently replaced the MPI relay (next to the ecu) with a NEW one. While i was in that area, i took my ECU out and opened it up. There were no leaking caps and everything looked fine in there.
I'm stumped. I think i might invest in a fuel pump rewire kit, since even the test connector won't work on it.
I don't want to shell out 180$ to have my ECU rebuilt if that's not the problem. I have no CEL, and there is no "clicking" or bad smells from the car when it's on. Is there any way i can "test" my ECU to see if it's good or needs replacing?
One thing that i figured i should mention. When i got the car, the CAS (the sensor on the valve cover) sensor was off the car and the previous person had cranked the car over without the sensor on. I bought a NEW sensor, but i do not know if the sensor has to be in a certain position? If the new CAS is plugged in but not installed, the car should still get spark, right? While the key was on the ON position, i moved the coil around and accidentally sparked it on the strut tower. This means the coil is bad?(the power transistor is good, right?)
I'm just out of ideas right now and i'm thinking of rolling the car on a trailer and taking it to someone who can fix it.
Just actually recived my car today, and no start, turns over fine,it is just not getting any fuel, so I replaced fuel pump with Venom high volume (was planning on anyway), replaced fuel filter.... still no fuel, then checked power, not getting any to pump, like i said i am very green with these cars and need help... where is the ecu located? and the relay next to it controls the fuel pump?
>The previous owner said he had the car sitting for a while, would go out once a week and start it up and the last time he went to start it nothing happend...... it is also having clutch engadgement issues... it has Brand New clutch M/C and slave, but still having problems engadging, you cant put it in gear! i do know he had the cluch assy completly torn apart and put new parts in>>> are there any adjustments i should try before replaceing all the parts again? possibly clutch fork or pivot bushing (fulcrom)?
the ecu is behind the stereo in front of the console, the fuel pump relay is next to it on the right hand side.
Originally posted by pinknuggit
If the fuel pump relay was bad, would the pump come on with power to the test connector?
No - Except if the Fuel Pump Relay was "bad" & stuck closed - THEN the FP would run even with ignition off till the Battery died.
