Show me your Hood Pins!!
BacknBlack92ESi
2,340
Feb 19, 2003
Kansas City, Missouri
Im getting Hood Pins tommorrow, Just got a new hood, but latch wont work:mad: I tried everything. So i gave up and said I just want Hood Pins. So you 1G guys w/ Hood Pins. Show me.
What ever you do don't buy the cheap AutoZone/PepBoys hood pins. If you scratch the covers trying to get the pins in they'll look bad and probably rust. I also scratched my hood when a pin was being stubborn. I'd get the kind that has a ring on the pin. You move the ring to the other side and then pull on the ring which pulls the pin out. You also won't loose the pins with these. Just my $.02 ! Later.
This shot was taken from my hotel room at nopi. The eclipse on the right is mine, the one on the left is a guy running a 200 shot from 2gnt.com. My hood pins are functional. I need them because i dont have a hood latch due to my dual stage oil cooler being in its place.
I have since painted them black, so they are less noticeable.
here is where I mounted them, between the rear headlihgt bracket and the radiator upper support.
umm i'm sorry i know that it's off the subject but is it even safe to run a 200 shot won't u like blow your motor out your exhaust???
PC Talon thats the exact spot where i put mine. Ill have pics up in a few due to i just woke up:thumb:
heres mine... dont mind the different color hood and bumper, Im painting my car that color:D
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
