Should I have boost leak here?
djseclipse
145
10
Mar 6, 2006
stony point, North Carolina
Just finished several boost leak tests. Fixed leaks at the TB gasket, biss screw, bov adjusting screw, and j pipe weld. But it will not hold the 15psi I am testing at. Takes about 5 seconds to lose pressure. I noticed that all the air is escaping from the recirc. tube that connects my bov to the intake pipe ( disconnected from intake pipe). I have the dejon greddy knockoff. Is this supposed to happen? Or could I possibly have the bov to soft? While driving the car holds boost fine and does not surge even at 1psi. I did bypass mbc while testing. Any help is appreciated!
Not sure if I read this right or not, but here goes: make sure the recirculation tube is attached at both ends (BOV and intake) with radiator claps and that should hold the pressure. I do my leak test off of the turbo inlet and just cover up the bleeder hole on my MBC, hope that helps:) .
Yes your settings are too soft on the BOV for whatever psi you are trying to run. I haven't ever used the knockoff versions so I dunno how well they old up.
  • Wanted 6 bolt NT water pipe
    • chrisman287
