should i get a data logger? and if so...
diputz42
54
Aug 30, 2004
Dublin, California
is there a real cheap one out there that can do everything i need that can connect to a laptop? i cant exactly afford a palm right now, so id rather use the laptop thats laying around if possible.
but the reason i ask if i should get one is cuz im a dsm newbie. i just got a stock '92 gsx and im not sure if a data logger is needed yet... thanks guys.
SON OF A....
the laptop doesnt have a serial port on it. is there a serial to usb adapter or a sub version of the logger?
i think i am going to get a palm pilot... i just saw some palm m100 on ebay for like $10 + S&H. are the m100 good/fast enough for logging?
Only thing I can say bad about the cheaper Palms is that if they done have a recharable battery in them and the battery dies, you will loose the software and all logs. You will have to put new batteries in and load the software again. If I were to do it again I would get a Palm that charges itself on the cradle.
Also get one that is backlit so you can log at night.
i just bought a palm m105 for like 30 bucks and bought data logging cord for 55 so i spent about 85 dollars and i am happy with so the setup is less than 100. the only thing i would suggest is find a datalogging cord for cheap that uses the palm its good for what you want to do at this level
palm m100 - backlit, $20 on ebay
just make sure the backup battery is good and you'll be fine
link plz :)
but doesnt the m100 use AA batteries which would make it non-rechargeable?
