short in the door
marsh63
517
Oct 15, 2007
richland, Washington
ok i just tried replacing my blown door lock fuse and right when i pu the new on in it blew out. so is it a swicth problem or a loose wire somewhere?
The first place I would check is the wires running through the door. When you open your drivers door if you look in by the hinges you will see the boot that covers the wires. Pull the boot back and check the bundle of wires for a broken one. It is a common problem area on most cars. Keep us posted. Travis
