Shifting
dsmdizzle
105
Jan 7, 2006
Ogden, Utah
Okay the clutch on my 90 gsx went out 2 days after I bought it. I replaced it, bled it and now it is hard to put into gear. I had adjusted it and it is all the way to the point where it will not be able to go any more. Why is it so hard to shift?
Is the clutch stock? I take it that this particular problem was not evident before the replacement of the clutch.
Don't force it into gear as it's hard on the forks, synchros and everything.
If you are absolutely sure you got all the air out if it, I would double check my install. This is assuming this is not an ACT 2600 or such. If it is, I can give you a thread to read.
Good Luck
Maybe the clutch wasn't bad so much as the pivot ball? Was it difficult to put into gear before the clutch swap?
