Shifter broke apart
Trison
51
Aug 30, 2011
Sierra Vista, Arizona
Unsure what the silver C clip is called that holds the Rod that connects to the shifter. But it popped off and it came apart during shifting. Unsure if there is a better way of keeping it together or if i have to get a new clip thing. If so where do i get one and what is it actually called? Thanks.
Is the rod you mentioned in your first post the one that the shifter lever pivots on then? If so, was the clip on the very end to hold the shifter from sliding off? In the diagram, the location I'm referring to is secured by a nut. The only c-clip secures the actual shifter cables.
