Shaved valve cover.
JesterJess
85
Sep 1, 2009
Olathe, Kansas
I am working on rebuilding a NT 94 Eclipse that I just recently picked up. While I wait for my block to come back from the machine shop, I'm pulling my hair out finding something to do. SO, I whip out the right angle grinder and a few pads and get to work. Let me know what you guys think about this. I'm not done with it. I need to hit it with a final pad and get the rest of the scratches out, but here is a "first step."
Looks good so far. I did mine almost 7 years ago. Be prepared to polish it on a regular basis. When I lived in Michigan it got very corroded very quickly in the winter from all the road salt.
Not bad. I have one too. I use this on all my polished parts and they are blinding when the hood is popped open.
Mothers® Mag & Aluminum Polish. I get it at Walmart.
Looks pretty good, looks a little 'wavy' yet. I'd break out a block and some sand paper and go over it a little by hand.
I just got through restoring one myself. I thought of shaving it flat with and manual end mill just too many angles.
Does everyone else just grind them then block sand it flat?
I used a grinder on the bulk of it, then hit it with 60 then 120 on an orbital, then block sanded up to 600 or something. Came out flat and looks good, no pictures of it bare, but then i had turboglenn weld some fittings on, and sent it off to bonehead to get powder coated.
That's a sick powder coating. Looks like two differet V/C with the light hitting it at two different angles. I'm going to have mine painted to match the body color of my 1GB. Also, I started with a hard green #80 disc on an angle air grinder to take off 90% of the material. Then I went to a red pad to knock the rest down til it was level. Then onto a blue pad to polish all the red scratches out of it. NOW, I need to hit it with a block sander with some finer sandpaper. I'm not going to spend TO much time on it cause a high fill self etching primer will fill all of the imperfections. I will also block sand after a couple of coats of primer then have it shot to match the car.
those are some nice valve covers. I shaved mine and polished it. Then it happened the rest of the engine looked crapy. So after about 50hrs of sanding and polishing, Im still not done. I will deffinetly pick up some of that mothers polish.
So, here is the finished product! There was one small dimple in the valve cover that appeared under one of the letters. I should of filled it with filler before I painted it, but now it's too late. I know it's not perfect, but It looks sick in person. In the pic, with the flash hitting it, it seems worse than it really is.
doesnt look to bad. i really only see only low spot, but it looks nice
The hardest part was removing all of that old powdercoating without access to a bead blast cabinet. I used brake clean and a brass wire brush to prep the surface, then I painted it hanging from my garage door last night.
Looks badass!
Where did you get that piece thats holdong all you spark plug wires together by the intake cam gear? never seen it and I want one.
    • Sdcryan1
