ZmanIV
- 269
- 4
- May 27, 2004
San Diego,
California
I installed my coilovers D2 and I am in the process of adjusting them.
The rears were set incredibly stiff, I removed 15 mm of compression length from each side (don't know how the previous owner got them that tight) coils free length with wheel off the car is about 7 inches. when I lower the rear of the car it settles about 1/2 inch.
Should I reduce the rear spring rate some more?
The fronts are the opposite they settle about 2 inches when I lower the car.
Should they not settle that far?
I did measure the wheel distance to the top of the fender before I started doing all this and I am now about 1/4 inch off.
Thanks Martin
Thanks Martin
