Serious Lurching Problems...
diab0liK
133
Feb 17, 2005
Ann Arbor, Michigan
I just replaced the fuel filter today, hoping to alleviate a problem with some shaking on the expressway after a couple hours of driving, over 55-60 mph. Fortunately, I managed to make my car worse in the process.
I also did oil/oil filter/air filter at the same time.
Spent 4-5 hours wrestling with the bottom nut (the 14mm) on the god awful 95 fuel filter....it's bad.
Anyway, finally get it off, bolt everything back up, and take off.
Of course this results in a violent lurching at pretty much anything over 10mph. The lurching is constant, and refueses to go awawy.
Anyopne with suggestions, I would greatly appreciate it.
Here's a link to another forum w/ more explanation of the problem............ http://www.xceedspeed.com/forums/viewtopic.php?t=32863
Thanks in advance
Sounds like your plugs are fouled.. Check the plugs and plug wires, if you haven't already.
  • Wanted 6 bolt NT water pipe
    • chrisman287
