Need Serious Help!!!
Electric Talon
Feb 5, 2004
Kennesaw, Georgia
Help!! Blew oil and now my Talon is dead. I am not completly sure wheater or not the engine is locked down or not because I did not hear any grinding, popping, or snapping. When I blew the oil it was in passing gear at 5500 rpms the oil pressure dropped ( of course) and the engine dropped to 3000rpms I pulled over and it died. Now if I turn the ignition it just clicks, this sounds to me like it might be an oil pressure shut off valve, but I don't know if there is one or not. By the way this is a 420A. If you have any ideas or suggestions I would greatly appreciate it. Thanx :talon:
so you checked and there's no oil in the pan correct? Check your t-belt, see if it broke.
  • Wanted 6 bolt NT water pipe
    • chrisman287
