Serious HKS Turbo timer prob
Mitsu725
211
Mar 22, 2004
DAVIE, Florida
i bought the car w/ the timer pre-installed with a factory alarm, then i bought a clifford g4 alarm with blackjack and the installer tells me that the turbo timer is wired wrong but wait......."he can fix it" he fixes it and then the car battery goes dead like every 2 minutes i found out i am getting a power draw from the turbo timer because its wired in the way its supposed to be if u have a factory alarm and now i have a clifford alarm, well i am going to buy the harness now so i can get rid of his crappy wiring job but the harness looks like it has three plugs, one that goes to the turbo timer and 2 that go to the ignition, well i dont have a plug on the back of my Timer i guess whoever installed it the first time cut it off, so now i dont have a plug for the back of the timer, that will actually plug into the plug and play harness im going to buy. So what should i do, but a whole new turbo timer not chopped and screwed with a harness or try to fix mine somehow???
I believe I still have the harness from my old hks turbo timer that is in good condition. Let me know if you want it and we can work out a price (cheap). You should just be able to solder it in and plug and play, it would be a lot cheaper than buying a whole new turbo timer.
yeah but i need the harness that goes from the turbo timer to the ignition and the plug that is supposed to come on the turbo timer itself so that it "Can" plug into the harness for the ignition ### mine is just a turbo timer with 4 or 5 wires hanging out the back with absolutely no plug so ig u have that then ill definetely buy it PM me with a price.
i just need that white little plug and ill be set.
Well I looked for the wiring harness that comes off the back of my old turbo timer but my wife ended up throwing it away. I still have the plug and play harness that goes into the steering column. You could use this, directly solder in the turbo timer to where the plug would be and that should work the same way. You only need to solder the red, blue, and green wire for it to work properly.
