serious clutch problem driving me nuts!!!!!
Logue
408
6
Sep 27, 2003
Tuckerton, New Jersey
my clutch is being ###, when i drive around on it i'll push to the floor as i'm shifting gears and it returnes slowly only sometimes though the after about maybe 20 miles of driving the clutch will just stop working won't go into anygears. but i'll bleed the clutch it will work perfect agian. for another 20 miles. i can feel the peddle losing pressure as i drive it when i first bleed it theres is no i play then as i drive i can feel play in the peddle where its soft and doesn't do anything like an inch or so of pedal at the top. so i bought a new slave cylinder thinking it was that. installed the slave cylinder bled the system and it felt awesome for 5 mins. then it started to do the same thing. i inspected the master cylinder its not leaking anywhere. even when i check the fluid level it doesn't seem to go down when i have to rebleed the system to get the clutch to work. does anybody know what i can do to fix this i can't drive my car really and i need it asap......
thanks,
JJ
Generally its a good idea to replace the master cylinder at the same time as the slave. With that being said, im gonna say its that. Any fluid coming into your car at all? (near the clutch pedal) Have you checked the lines?
