Searching for Injectors blues....
IceDragon
547
Jul 13, 2004
Gilbertsville, Pennsylvania
I am searching for like 290 up to 320 injectors... I seriously need these and yet i can't find any, i am hunting up and down, searching google... everything, can someone, anyone help me?
Yeah, they are 390 and low impedence... na90dsm helped me alot, found i believe 310cc injectors high impedence and I am gonna get them.
I'm looking for some HIGH IMP fuel injectors as well. With my huge ram air intake I'm running lean. I need bigger injectors. Can some one help me out. :) I looked at the link above. Is there any other place that does that.
That's total nonsense. Unless your ramming air in after the MAF it's really unlikely your going to cause the car to run lean and very unlikely you are ramming enough air to require bigger injectors.
Try making sure you don't have intake leaks.
Steve
i had full exhaust,injen intake, spark plugs and wires, test pipe, ported headers, air duct in bumper and i didnt run lean at all.
you need some serious modifications on a stock n/a to outrun the stock injectors, youd need cams,pulleys,bored tb,and a lot more.
actually all you need to run as lean as me, which is actually not that lean, but lean enough that i shouldn't be driving too much... is turbo intake cam, 3 inch gm mass, and the MAFT, along with a full 2.5 inch exhaust...
