scattershield, buschur intake pipe, and rad hose
91MITSU0
Feb 13, 2005
greensburg, Pennsylvania
I recently installed a three speed scattershield and now I am trying to reinstall my intake pipe the vpc one that puts the filter in the fenderwell. However I can not get them all to fit because nowthe radiator hose is being pinched between the two. Just wondering if anyone else has had this problem and if so how were you able to fix it. Thanks in advance,
e mail me at info @ three-speed.com (remove spaces) I will help you out.
A picture with the e mail is also helpful if possible.
Intake pipes as large as 4.5" will work with the shield.
try to invert the lower radiator hose...the side on the radiator put it on the steel pipe :D ...and vice versa, and it will fit
