Say Something About The Person Above You
Status
Not open for further replies.
Fixed the timeing it is off maybe a hair.
<embed src="http://img531.imageshack.us/flvplayer.swf?f=T051809210100bi3" width="320" height="260" allowFullScreen="true" type="application/x-shockwave-flash"/><br/>
<a href="http://profile.imageshack.us/user/edm95">[More videos from edm95]</a>
Should take the fuel pump fuse/ relay out for a compression check..You want it do do everything but squirt fuel..Unless your supposed to dissconnect the spark too..
Slickers, just buy the 1g auto...There just as fun an a stick if driven correctly..Plus you can just get in the car and go, no need to shift..Unless your me..
But but but, I want a stick......
Ill see what I can do. If anything, I would take a Mani. Turbo. Then Auto turbo, then Mani. N/T.
Im not going to buy a N/T Auto.
Will probably want a Defi gauge after he see's this...
Here is the numbers
1G (90-94) T/E/L----------1.8L NT engine ---------------2.0L NT engine---------------2.0L Turbo engine
Compression ratio------------9.0:1-----------------------------9.0:1----------------------------7.8:1
Standard compression--------185 psi----------------------------192 psi------------------------164 psi
Service limit--------------------131 psi-----------------------------145psi-----------------------121 psi
2G (95-99) T/E-----------------2.0L NT 420A engine----------2.0L 4G63 Turbo engine-----------2.4L NT Spyder engine
Compression ratio----------------------9.8:1------------------------------8.5:1--------------------------------9.5:1
Standard compression----------------170-225 psi------------------------178 psi-----------------------------192 psi
Service limit-----------------------------100 psi----------------------------133 psi-----------------------------146 psi
How to do a Compression Test
Not bad just low compression. So you can run it but the pickup power will not be there. Just go ahead with the rebuild or swap it..:thumb:
Here is the numbers
QUOTE]
I know those are the mits numbers, but they look a little high..Must just have been mits with alot of misinformation..Kinda like how they say to gap your plugs at .032 for a turbo car..
So Ed..Replace your vacuem lines and do a headhasket..Not hard to do if you have the car apart anyway..Or on the right side the headbolts weren't tightend all the way resulting in a gap between head and deck.. But could just be bad rings, which all you will have to do is unbolt crank and pistons and re ring them..
Status
