Safc Neo Questions. Please Help Gurus! :)
dnbmovement
70
Sep 9, 2006
Miami, Florida
So i just finished installing the AFC Neo and i just wanna make sure things are right. I read the write up for SAFC-II and the ecu colors didn't match up. The RPM and Battery readings on the AFC work. The only thing i wanna make sure of is if i wired the MAF right. I took #10 pin out(MAF) and cut in half and spliced as needed. Is that right? How do i know if the AFC works? Right now im on stock 450's and getting ready for 680's. One last thing. My stock boost gauge(computer estimate) is stuck straight up. <- Thats why im making sure. I hate car electric :(
I ran a bad wire..... Boost Gauge problem solved.. Now for set up. I have 450 injectors in an automatic and its running like a pig. What should do to set it right? No logger right now, being shipped.
Problem Solved. Maybe its just me of the VFAQ write up has alot of flaws..... Crossed wires for the MAF. Thanks
I'm about to put the neo in my 4g64 could you right up what colors went where since they did not match up like the safc ii
The writeup for the SAFC/SAFC2 cannot be used when installing the Neo. The colors for power, ground, throttle, and rpm are the same, but for the Neo, the wire that goes to the MAS is black/white, the wire that goes to the ECU is brown/white. The orange light is the illumination wire for the display's backlight.
http://www.apexi-usa.com/pdfWiring/13.pdf
This and other installation instructions for A'PEXi products can be found here:
http://www.apexi-usa.com/support_wiring.asp
http://www.apexi-usa.com/support_installation.asp
What write-up did you use? I want to see if it needs any correction/updates.
Mines a 1g :(. All i did was go to the VFAQ and compare colors and their functions. Do the same and just hope that the colors are right.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
