SAFC II question
Velo_TalonTSI
Sep 4, 2002
West Valley, Utah
In the tuning guide for the safc it says "Now, you want to use baseline corrections for fuel injectors. If you have 450's, leave both tables at zero. If you have 550's, put them around -10%". I don't understand where this baseline -10% value is suppose to be put into the safc. I'd appreate any help. thanks.
The guide should say whether the -10% baseline should be put in the lo or hi setting on your AFC.
Go to "settings" then to "lo throttle" then from 1K to 7K individually set each rpm to a "baseline" depending on your injectors. You will then need to start up the engine and monitor o2 feed back trim and adjust from there. Good luck :thumb: I had to read about three different AFC tuning guides untill I got it.
