General SAFC II Correction?
OneFastEclipse
255
Jun 20, 2002
Canton, Ohio
On the SAFC II when you are tunning fuel, when you go into the negative numbers your subtracting fuel and when positive your adding it right? So if I wanted to account for 550's in the beginning I would put it at -10% all the way accross correct? On the pocket logger, if the fuel trim is positive your are running lean and in the negative your running rich correct? Thanks.
On logger, anything above 100% is running lean as the ECU is adding fuel and less the 1000% being rich.
AFC you got it right.
Yes and yes.
yo2001 - on 2gs they are positive and negative for the fuel trims.
