safc 2 install
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
alright guys i get everyother wire install but this one the pink and orange wires. i know they go on the same wire but i cant tell which one it is on vfaq. the pink wire goes further towards the ecu connector and the orange one goes behind it but what wire do i use.. is it the airflow signla (a blue w/ yellow) need help asap. hooking the rest of the wires up right now!
DId you buy it new or used
If new, follow the damn instructions liek i did. Good god, it tells you where to put what.
If you got it used, i know there are a few wires that arent used when i put mine in
I can't verify the wire color, but YES, it's the airflow signal. This is the one that's cut because this is the signal that the SAFC actually modifies.
The wire is cut. The end running to the MAF is connected to the orange wire. The ECU end is connected to the pink wire.
