S362,30psi,which injectors?
ceedawg
Supporting Member
1,527
216
Nov 9, 2002
laurelton, New York
I have been reading through dsmtuners,highboost forums and evom,for a few days now. I am still confused as to what injectors to purchase,1250's,1650's 2150's.
I already have -8 feed from pump to rail and -6 return lines
255 walbro which I'm gonna chg out for the new Deatschwerks DW300 High Flow In-Tank Fuel Pump.
Want to go Pump gas.
Motor is fully built! Plan is to run from 25 up to 35psi when necessary. I don't plan on going bigger with the turbo, the S362 will be it.
Some say 1650's others say 2150's Im confused. I do not plan on ever using E85.
Any suggestions?
with 91 1250cc is enough, with 1600cc plus would idle rough it depends though.
Read in one thread that the 2150's idle gd surprisingly, by the same company that sells the fuel pump I mentioned.
Yes drivability and idle would also be a concern. If the 1250's would work with my present setup,I will get the 1250's.
Got new 950's not installed,I was afraid they would be too small.
FIC 2150 or ID 2000. Then be done with it, they idle better then my old PTE 1000s. You need to know how to tune your idle though.
Jeez! Mo $ mo$ mo $"!:p Guess I will have to do it. As long as the 2150's would'nt have a problem tuning with my AEM EMS I guess I'd make the move. Gotta sell these new 950 FIC injectors though.
  • Wanted 6 bolt NT water pipe
    • chrisman287
