GstRacer
- 409
- 3
- May 6, 2003
BooneDocks,
Connecticut
ya someone was telling me that the more bends in your IC piping equals less less hp is that tru or not??
98spyderboost said:Don't people have pipe benders any more?
MNGSX said:Unless they are severe and restrictive it mostly effects spool... I have heard it said that each 90 effects as much spool as an extra foot of piping...
Limit the number of bends and keep them gradual.
DSMJim said:A 90deg mandrel bend is equivelant to 6 foot of piping. It however will not cause much of a restrictiction.:
DSMJim said:Nobody has proven that a short route car with the same mods is slower/faster or better spool than a long roupe piping car to my knowledge. If there is a difference its going to be small.
Lets put it this way, on most of the short route piping kits the intercooler outlet on one side is a hard 90 deg which is going to cause a lot more restriction to flow that long route piping will.
Voila, you think that a few bends is worse then that hard 90 deg angle outta the cooler like that?
did you even go there. oh im sorry your right they are the same pretty red pipes. look under front mount IC.GstRacer said:dude did you even go to dejon tool they have the same pipes as in my picture. I'm looking to find the short route like what anconover posted
MNGSX said:I have short route but normal endtanks w/o a hard 90.. I have a wider radius bends throught the system and kept it short and did'nt use the stock UIC path. I did'nt think those tanks like in the picture flowed well so I avoided them..
