Rust on my wheels.
RedLinE-
Jan 2, 2005
Neosho, Missouri
Alright, so I recently bought a GSX and the stock rims have a little rust showing. I was wondering if a rust remover substance would work, or if anyone has tried anything else to get rid of the rust.
are you sure it isnt corrosion? i had real bad corrosion around the outside edges of my wheels. i decided to use paint thinner and strip off all the paint, sand off the corrosion, and then i painted my rims black. i however neglected to primer them and now they are all messed up cause i just got tires and the tool they used to put on the tires took off a lot of paint on the outside.
