runs great when cold but when its warmed up ..........
akagotcha
Aug 21, 2003
92 nonturbo well heres the deal it starts up fine idles fine but when its been runing for about 20 mins it doesnt want to pass 4000rpm i changed the o2 mass air flow pcv and the tps all vacum lines are hookeed up right and do not leak i also have shitty gas milage about 180 miles to a tank and top speed is 85
:talon:
could that also be the reason why the coolant light stays on even though i know the levels are fine i mean the operating temp is running temp and everything.
i would also check ur ecu, that happened to my friends gst and once his car would warm up it would run like ass, check to see if it smells like rotten sea food under there, then go from there
conclusions are blown headgasket hundreds of dollars later i think i should have looked at it a lil differently i guess resedue in the exhaust milky oil the coolant leakin into the cylinders caused it to skip under high rpm and cause of loss of power thanx for the help though i just wish i known it sooner before i put the hundred and hundreds of dollars that didnt fix nething :thumbdown
good news gasket only 33 bux and a couple hours of my own time
