Running super rich after swap.
Laservision90
Aug 15, 2013
New London, Wisconsin
So I just completed an engine swap from a time jumped 4g63 to a running one. I pulled the whole motor out, transferred everything to the new long block and put the motor back in. The car that I put it back into was a stunningly clean Plymouth laser fwd turbo, oil cooled and driven by an old man until the timing jumped. Because I'm from Wisconsin and the car has no rust I decided that it would be worth picking it up for scrap and putting a new engine into it. Well I put the new engine in it, all new timing components, after pump, and all that, then I started to do the classic swap cycles, "test run, fix, repeat." Well the car has normal power and acceleration until 3000 rpm. But as soon as it hits about 3.5 it stumbles and blows smoke (obviously running really rich) I took the set of plugs out and I put new ones in and took it for a five mile drive. When I pulled the plugs out to check them, they were coated with black soot. (Obviously fuel) there are no check engine lights on in the car, (but it is obd I so....I'm not sure). My question is where would any of you start looking for a fuel problem? Because I've never seen a motor DUMP this much fuel into a motor after a swap.
Thanks for all the help in advance.
Hmm while when I had the cat pulled it ran super good too...the maf would send the same signals seeing as it had no rear oxygen sensor. Think it could be the front 02?
